Purchased wrong add on
walker_tim
I thought I was purchasing a US Roaming add on, but it turned out it wasn't US Roaming. Is there a way to get a refund?
hycm53
You could get refund if you made mistake and didn't use it.
Contact PM customer service to require refund,  click here
Meow
You can ask agent nicely explaining your mistake and ask him to provide refund or most likely to add funds to your account to be used on next renewal.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
@walker_tim
Yes, if it is an honest mistake and the addon was not used, PM support will usually reverse the transaction and put the fund back to your My Account and you can repurchase the correct one
Please open ticket with PM Support
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
A reminder, US roaming has a 10 days, 240 hours, expiry and it will kick in once the purchase is completed.  So, buy when you really need it, not buy ahead of your trip
Outdoorsman
@walker_tim
Hi to ask for a refund you need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
      https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
