Transfer
Scottman
I'm trying to transfer my old number to public mobile but I entered the wrong account number and now I cannot get a hold of anybody
2 REPLIES 2
slusagm
@Scottman
There is a porting assistance team you can call and ask them to update the info you provided.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to open a ticket with  Public Mobile.  Simply open ticket with PM using Expert Messaging.  Click the Orange Chatbot icon on the lower right to start, or use this link https://expert-messaging.publicmobile.ca/guest/chat/
 (Use your Community account to login.  For 2FA, you might need to use email to receive if you cannot receive the text on the phone.)
PM will reply you via Expert Messaging   between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
hi @Scottman
  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),Please use the same Community login you are using now.  (If you get stuck with the login or 2FA code, then use a different email address to create another Community account and submit the ticket with this new account):  https://expert-messaging.publicmobile.ca/guest/chat/
          Once you started the Chat, type "Submit Ticket", then "Connect Agent", and it will ask you to login to open ticket
          (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email" or "Send Voice Message")
Remember CS_agent will reply within 2 to 4 hours.  You will be notified via SMS/email or monitor here:
