User name and password
Kev0711
Hello my user name and password isn't working
hycm53
When you login your self service account, you need your email address not your user name .
If you forget your password, click "reset password", then PM will send a link in your email.
Outdoorsman
@Kev0711
Hi if password reset is not working you need to contact a cs agent to change/reset account email you need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
      https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
will13am
@Kev0711 , please try using incognito mode on your browser.  See if that helps.
@Kev0711
did you try to login with Incognito mode?
 did you try Reset Password link there and put in all the possible email address you might have used
if none of those help, please open ticket with PM support:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
