Promo and referred by friend
Jr72
I just activated my sim and account and mistakenly went by the promo code and referred by friend. How can I fix this mistake and add them on now?
JL9
This issue has arisen many times before and a CSA can usually resolve it for you manually as long as all conditions are met, etc.
Jr72
Thank you, I couldn't seem to get along with the chat bot so am trying the private message option, fingers crossed. Thanks
@Jr72
Yes, if that is an honest mistake, PM support are very understanding and likely able to apply it back manually.  Just open a ticket with PM Support :
1. If you have access to My account: Click on the bubble on the lower right or https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
