Missing Points - Refer A Friend
TWZ
 Closed.
slusagm
we are just customers here, please remove the phone number
so, it has been couple months, you sure your friend still using PM?  and she ever got the $10 credit when she joined?  I think you need PM to check.  Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
AK32
You will need to reach out to a public mobile agent to help you add that if it was truly missed on their end. You can contact them directly here:
Phil_Adelphus
@TWZ   Please tap the little v in a circle top right of your post to edit your post and remove Karen's name  and number as this is a public forum that anyone on the internet can see.  You need instead to open a ticket at the chat icon bottom right of this page or private message support using this link if that doesn't work
kb_mv
@TWZ You should really edit your post to remove personal details. This is a public forum and we are customers like you. You will need to contact customer service at the link below. Your friend may have to as well to ensure the code was correctly applied when she joined.
Edit spelling
