04-10-2024 06:34 PM
I need my account number in order to complete the porting of my number to Virgin mobile
04-10-2024 07:41 PM
@Tamtam1 If you don't know the email address you used you'll need to contact the CS Agent at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 to assist you. They'll ask you some questions to verify you own the account. If you can't answer them, they won't be able to help you. For instance, you'll need to know your phone number, the PIN on your account, address on the account, etc. Good luck!
04-10-2024 07:00 PM
You should have options.
If still doesn't work, use the bot and type agent or support.
when porting make sure this account is not closed.
04-10-2024 06:43 PM
I’m not able to log into my account. Don’t remember what email was used
04-10-2024 06:36 PM
Sign into Your Account and click on Profile. You will see it there hold your cursor over the 🖊 to see full number.
04-10-2024 06:35 PM
@Tamtam1 You can check this yourself. Log into your account, go to profile and it should show the account number there.
