04-10-2024
05:41 PM
04-21-2024
10:29 AM
Dunkman
2FA does not work,, it says it is sending code but I am not recieving it. Tried 20 times
04-10-2024 07:54 PM
Started porting at 4.20 pm It switched to my old number almost right away but the recieving text and calls still does not work,,, Imessage/ facetime is an internet program so it works fine
04-10-2024 07:47 PM
@C10B It sounds like the port hasn't fully completed. How long ago did you go through the port process? I will send you a PM will the number to contact the port team if necessary. I'd give it a bit more time if you just completed your port. If you're having trouble with imessage or facetime (iPhone), try to restart the network settings.
Tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
Apparently this is a known issue they're trying to resolve.
04-10-2024 06:43 PM
Got it to work by putting in old Bell sim, but back on PM now , can make calls but not recieve
04-10-2024 05:51 PM
@C10B Is this a new activation? Are you able to receive other SMS messages on your phone? Has this worked in the past? If you've been able to login before, you can click on the "Didn't get the code?" link and you should be able to have the code sent via email. If you haven't logged in before send via email option won't be available.
04-10-2024 05:45 PM
do you see an opportunity to have it sent to your email instead ?
