3 weeks ago - last edited 3 weeks ago by computergeek541
Hi, trying since yesterday to switch from fizz to public. No message to confirm, now I'm stuck between 2 operators and I can't use my phone. Could you please send the phone number of the porting team? Thank you
3 weeks ago
Topic closed. Thank you very much for your support, I called and now the transfer is almost done. Really appreciated!
Have a great evening!!
3 weeks ago
@Wave07 no worries I’ll send yo the number right away private message
3 weeks ago
HI @Wave07
It could be an incomplete port. You should ask Fizz to rerequest
But you can also check with PM porting support team. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
