11-22-2024 02:21 PM
Hey I purchased a plan with you guys last night I had the eSIM on my phone the service was not working so I thought I could simply remove the ESIM and reinstall it however I cannot log into my account because I can't even access text messages to my new phone number set up with you guys
11-22-2024 02:33 PM
@Jewsika no worries support can help you at this point to fix issue
11-22-2024 02:25 PM
@Jewsika you should be able to select "Didn't get the code" option and then select to receive the confirmation code via email that is on your account
11-22-2024 02:25 PM
HI @Jewsika
you shouldn't have delete the esim. Esim is one time install, so you need a new one. But if you cannot login the App, you won't be able to get a new one yourself. Please check with support agent for help on this
you can submit ticket by direct message:
11-22-2024 02:24 PM
you will need PM to regenerate another esim for you. You won't be able to open proper Chatbot ticket, so just message them
