07-27-2022 04:01 PM
Hello,
I need to port out my number but I do not have access to SMS (out of country). How can I proceed?
09-15-2022 04:27 PM
Yes, my PM is active. Fongo responded Your request has been sent to your current carrier. Other Texts are coming through.
09-15-2022 04:23 PM
HI @cellphonesaver usually you should get a text within an hour
But, porting into VoIP could be slightly longer. Make sure your PM account is active and you can get text without problem. Wait a full day and first contact Fongo and ask them if they send the request yet. if they did, then you can ask them to send again
09-15-2022 04:21 PM
Hi, I initiated port out FROM Public Mobile to Fongo today but did not receive text message from Public Mobile.
Do you guys know how long it's gonna take when and what should be responded?
Thanks!
07-28-2022 03:16 AM
@dabr wrote:@DiegoA You'll need to contact the carrier you are trying to port to and ask what they suggest for you to port your number out from PM.
If you want, you can send a private message to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
In this type of case, the porting of the phone number to the new carrier would fail as the text message from Public Mobile will not be responsed to. Ultimately, Public Mobile would have to release the phone number usuing some type of manual method inititated by the Public Mobile CSA.
07-28-2022 03:13 AM
07-27-2022 05:46 PM
Better to port out when you are back in Canada. Lot easier and faster to port out.
07-27-2022 05:13 PM
contact to new company and give them your account number,
and your account will be active in here.
07-27-2022 04:21 PM
