Voucher
09-15-2022 02:54 PM
09-15-2022 04:17 PM - edited 09-15-2022 05:03 PM
09-15-2022 03:02 PM
@Teena70 I think @dust2dust suggestion to ask CSA's to add it would be a better idea than waiting several hours.
Here's couple of links to ask for assistance. First try chatbot or try sending a private message to CS_Agent:
chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-15-2022 02:59 PM
Where did you get it? When did you get it? Try again in another hour. Only try twice. If it still doesn't work then you might need to wait overnight if you just got it. Or contact the support people and have them enter it in.
09-15-2022 02:57 PM
@Teena70 Have you tried adding by dialing 611? You may also need to keep trying over the next several hours as some vouchers can take upto 24 hours to become active.
