Poor signal
11-24-2024
12:39 PM
11-24-2024
12:40 PM
computergeek541
11-24-2024 01:08 PM
@Peterhddh wrote:Im using iphone 13pro max ios 18. Cant be phone problem
Starting to appear like maybe you in an area not covered by 5G...only LTE. Use this link to see if that's the case.
11-24-2024 01:03 PM
HI @Peterhddh
make sure you have the latest iOS and Carrier Profile
then Reset Networks Settings. And go to Network mode to make sure the mode is set to 5G Auto or you can try 5G On
and try in different area, and maybe try your sim card on another phone
11-24-2024 01:03 PM - edited 11-24-2024 01:04 PM
11-24-2024 01:02 PM
11-24-2024 01:02 PM
11-24-2024 12:58 PM
@Peterhddh - Here are the system requirements for 5G to work on an iPhone with Public Mobile:
- Has to be on iOS 16.5 or later
- Has to be an iPhone 12, 12mini, 12 pro, 12pro max or newer, or an iPhone SE 3rd gen from 2022.
- Has to have 5G Coverage
11-24-2024 12:46 PM
@Peterhddh You need to select 5G network in phone settings but if you have s20 series phone it won’t get the 5G network like it can with Telus for example
11-24-2024 12:42 PM
HI @Peterhddh
what phone do you have? I guess yours is a 5G phone?
try Reset All Networks and see if it works
Then confirm your network mode is set to Automatic
if possible, test your sim card in another phone as well
Last, if you need support to refresh your account, submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
11-24-2024 12:41 PM
could be no 5G in your vicinity. Could be you've selected LTE in Settings.
11-24-2024 12:41 PM
@Peterhddh wrote:and why am I on LTE instead of 5G
Which phone model do you have? It may not be compatible with Public Mobile's 5G network.
