04-21-2025 05:19 PM
I noticed for the past few weeks at work I would not be able to make calls back home due to not having a signal, and that in the break room my connection would work but still be poor at times (last shift it did not work at all, except for a few instances). Whenever I would go for walks around the neighbourhood I would experience no issues at all listening to music, but today I noticed that once I got outside the range of my house's wifi, my signal cut out. My phone is a galaxy a15 if that helps. Normally LTE would load just fine but now I only see the 4g icon with 1 or no bars at all. It's quite confusing as the map indicates my area should be covered but it's not. I restarted my phone as well but I haven't noticed much of a difference. Has there been recently issues with reception?
04-22-2025 05:18 AM
04-21-2025 05:46 PM
I think I may have fixed it? Toggled on/off airplane mode and turned off wifi, went for a walk again at the distance it cut out and it seemed to work just fine, 4-5 bars. If it continues to persist I'll reply here again.
04-21-2025 05:26 PM
I have a Samsung Galaxy A15, it works with LTE/3G/2G when I check my settings
04-21-2025 05:23 PM
What phone do you have?
PM is cutting one of the 2 bands on 3G network in some area. if you have a phone that not designed for Canada and your phone not on PM's VOLTE whitelist, you might be affected and need a phone that is fully compatible with the new network requirements here
