Monday
I purchased a cell phone plan of $29 monthly for 30G used in Canada USA and Mexico just now BY MISTAKE. My name is JIANJING ZHANG. My email is wzk75@hotmail.com
So Please cancel this order and refund the money to my account.
Thanks so much!
Jianjing
Monday
@JIANJING You should tap the v in a circle top right of your post and edit out your full name and email address since this forum is not private. Did you already have a plan with Public Mobile and accidentally changed it?
Monday - last edited Monday
By mistake?
Did you intend to select a different plan @JIANJING ?
ADDING: were you porting from another provider?
Monday
try asking PM for that. But please be aware that PM is a prepaid provider, they might decline your request. If they decline, ask them to remove the credit card so at least the plan won't renew next month
Without able to properly login you won't be able to open the preferred Chatbot ticket, but you can still message them
Monday
@JIANJING No worries just ask support to help cancel it and remove the credit card info on file right away
Monday
hi @JIANJING
if the plan was not fully activated, there is a chance you can get the refund
submit ticket by direct message:
