06-27-2023 03:03 PM
07-07-2023 12:17 PM
@dust2dust Same deal as TextNow for short codes: "Receiving verification (short-code) text messages requires an Unlimited Texting or Fongo Plus add-on." But it's cheap if you really need it just while travelling.
07-07-2023 11:58 AM
@Luddite- Does Fongo (for free) receive the 2fa codes? Textnow does not. It's a bit of negative to me that it doesn't. But nor am I willing to pay a monthly fee. I could probably pay a one time fee like other apps but not monthly.
07-07-2023 11:53 AM
@Luddite I don't even know the VM forward email service. But you can listen the VM on the app, good enough for me. But voice quality and connection is very bad with Fongo. Sometimes I dial a number, it is not connecting for minutes.. or I even give up, them magically it connects like 10 mins later!!! TextNow call quality is much better and more reliable
07-07-2023 11:44 AM
@hairbag1 I'm sticking with Fongo because I love the forward voicemail to email service; especially when I'm outside Canada.
06-27-2023 03:36 PM
will you have ready access to wifi while in Austrailia ? If so, consider downloading the free voip app TextNow to your phone. You'll select a free Cdn number so others can call / text you AND you'll be able to call / text most any Cdn and US number for free....all while using your wifi or separately purchased data. Theres other free voip apps out there too, but I've used TextNow for several trips and seems to work great.
06-27-2023 03:06 PM
@Jnetfisher1212 NO, you cannot.
PM has only roaming service in US and nowhere else
you need to rely on local prepaid SIM or travel eSIM
