Plan cost increase
Kiffy
Hi im wondering why my plan costs 16.80$ now where before I was at 6.85$
Edit by Dunkman: removed personal information from title.
2 REPLIES 2
Phil_Adelphus
@Kiffy  I'm not sure if it's possible to edit a title after the fact but try the little v in a circle at the top right of your post and select edit and see if you can remove your email address and replace it with something else.  This is a public web page that is viewable by anyone on the internet.
Sansan
@Kiffy yea, that's a big jump. Unfortunately,  the loyalty program has ended and moving forward you will be paying full price upfront.
See below.
There is no more loyalty discounts.
As of this month, you will be loosing the $$ discount. You will now have to pay your full plan amount upfront each month.
They will give you 5% back on your spending each month.
10 points on your anniversary date.
1 point per friend referrals.
1-15 points in helping out in the Community.
When you have accumulated 15 points, you sign into your account and redeem that for $15 off your bill. You can also use the points for add-ons starting at 5 points up.
https://www.publicmobile.ca/en/on/get-help/articles/move-to-public-points
