promotions
06-17-2024
11:21 AM
06-17-2024
11:25 AM
computergeek541
i recently received an offer from public mobile to upgrade to 6 GB of data at 4 G speeds for $22.00 per month and is that my total cost or is this additional cost added to my existing monthly plan?
Plans
06-17-2024 03:01 PM
Thanks for the heads-up. I'm on the old $15 plan where I only get 100mins/mth talk and was thinking of changing plans, then going back to the new $15 plan that has unlimited talk. Now I know that won't work so I've submitted a ticket to see if it can be done on their end, but I'm not holding out hope.
06-17-2024 02:54 PM
@ctrl_alt_del wrote:Don't know if it is true, but this is what I got from chat:2024-06-17, 2:43:32 p.m.can I downgrade my plan to the $15 one?2024-06-17, 2:44:02 p.m.To downgrade your plan to the $15 one, you can log in to your Public Mobile account and go to the "Change Plan" section. From there, you can select the $15 plan and follow the prompts to complete the downgrade.
In the communications quoted above, you've been provided with incorrect information. There is no $15 plan that customers can downgrade to by logging into the account.
06-17-2024 02:54 PM
only if the $15 plan is available on your My Account.
I think the Chatbot answer was from old knowledge base as there is no more $15 for existing subscribers. The lowest price for existing is the $19-1GB plan
06-17-2024 02:50 PM
06-17-2024 12:10 PM
It is a new offer to switch from your old plan to the new one. Data is like crack. PM wants to get customers hooked on more data at higher prices.
06-17-2024 11:32 AM
@Benny7777, also keep in mind that if you leave the $15 plan I'm pretty sure you will not be able to switch back to it as it's only available to new customers.
06-17-2024 11:28 AM - edited 06-17-2024 11:29 AM
That is an offer targeted at certain customers (mostly those on the $15 plan) to upgrade their plan from the $15 plan to the $22 plan.
It's really only something you might need if you are looking for considerable more data every 30 days, otherwise it's not overly beneficial for some.
So instead of paying $15 plus tax, you'd be paying $22 plus tax.
06-17-2024 11:24 AM
This is a plan chamge.
