Canada-USA 5G , 50 GB plan offer for $34/month
Nicktan
If subscribed to a Canada-USA 5G , 50 GB plan offered for $34/month:
1-  Is this price indefinite, or valid for a promotional period ? What would be the cost after this period?
2- Is there any limitation on the usage in the USA (like a maximum number of roaming days per year)?
8 REPLIES 8
DGG999
I found that I have to turn my phone off and then back on once I cross into the US. This may be because I have 2 sims but it makes the US / Canada thing work. I also have roaming and Volte turned on of course. AND in some places in NoCal it doesn't work. No service.
You weren't asking me, but I use it in the US regularly. Both for short trips and long trips. Service quality is great!
@Nicktan
for best talk experience in US, make sure you have VoLTE enabled in the settings.
Make sure to enable Roaming Data in Settings. (Just leave it enabled..there's not going to be any unexpected charges later on)
Make sure you're connecting to either AT&T or T-Mobile when in US.
DennyCrane
Unlike some other carriers Public Mobile doesn't have a limitation on number of days you can use your phone in the US.
Nicktan
Thanks. Did you personally use PM in the USA and how is the performance for calls and data (I have an iPhone 12)?
Nicktan
hi @Nicktan
1. price will be the same, permanent.  But of course PM has right to increase the price, but they rarely did it
2. no limit to the US message.  So, you can really use all the data in US 🙂
CharlieWhisky
Hi, indefinite as long as you keep the plan.
No limitations in the USA.
