05-29-2022 08:16 PM
Why is my account status displaying "Plan Expired” today. My service is also not working. Things were good yesterday.
My Account
Plans
Service
05-30-2022 08:28 AM
@Treicpe Glad it is working. Enjoy your trip
A reminder, with you manually selected another provider in US, make sure you change it back to manual selection of Public Mobile (or Automatic) when you are back in Canada
05-30-2022 07:49 AM
Thanks to everyone for responding so quickly. The Plan Expired message is gone with the autopay payment made today. Restarting the phone and resetting network got the service working again.
05-29-2022 08:57 PM
@Treicpe wrote:The Plan Expired message is puzzling and ominous.
Yes, that is a scary status. I always say it should just say Plan Expiring 🙂
05-29-2022 08:55 PM
05-29-2022 08:54 PM
Sounds good. Thanks
05-29-2022 08:53 PM
@Treicpe Automatic could be a source of the issue. Try it and try in different area
And yes, some area could have better signal on one provider but not the other. So, try both and see which one connects and which one connects better.
05-29-2022 08:51 PM
Thanks. Manual connection has not been tried yet. Can try that. We did travel today so perhaps the connection got lost in transit?
05-29-2022 08:43 PM
@Treicpe wrote:Restart and mobile network reset seemed to get the service going again. The Plan Expired message is still appearing ... Even after adding funds manually.
@Treicpe Your Plan Expired has nothing to do with your connection.
Plan Expired because your plan will be renewed tomorrow. PM will flag accounts as Plan Expired around 6pm the night before renewal. It will change back to Active after the renewal, early morning tomorrow or close to noon
So, no worry about plan expired. Just focus on connecting to T-Mobile or AT&T
So, which roaming addon you got? Talk? Text? Data? or Combo?
05-29-2022 08:42 PM
Restart of phone and network seemed to get the service working. The Plan Expired message is still appearing ... even after adding funds manually.
05-29-2022 08:41 PM
@Treicpe the Plan Expired should not matter.
I think it is just an issue with your connection in US.
Did you try BOTH AT&T and T-Mobile and see if you can connect any of the two?
Try to connect Manually and not rely on Automatic
Did you try to connect in different area ?
05-29-2022 08:41 PM
05-29-2022 08:39 PM
The US roaming add on was purchased. It had 6 days left and was working this morning. Service stopped this afternoon and the Plan Expired message appeared.
05-29-2022 08:34 PM
@Treicpe roaming? are you in US?
if you are roaming and you don't have roaming add-on , you won't have service
05-29-2022 08:32 PM
The last plan payment was 30 April.
I am roaming right now and can do limited troubleshooting. Cannot call 611. No other phones to try.
05-29-2022 08:24 PM
If it is tomorrow, then you should still have service. Renewal is is eastern time so you should still be good right now. Can you reboot your phone and maybe reset network settings.
05-29-2022 08:24 PM
@Treicpe wrote:The account is on autopay. Payment due date is tomorrow. Is that the same as the renewal date?
@Treicpe yes, that will be tomorrow.. So, it shouldn't be payment issue
Try to reboot your phone.
If fails but you have another phone around, put the SIM there to text. Or if you don't have another phone, try to reseat the SIM (power off, take sim out for a minute and put it back in and power up).
If still fails, check if your phone is connecting to the network or not. what message on the phone status on top?
05-29-2022 08:21 PM
05-29-2022 08:20 PM
Usually Plan Expired can be ignore as long as the service is not interrupted. Plan Expired usually just mean your account is going through renewal
However, since your service is not working, please check and confirm if your new renewal date supposed to be tomorrow or today?
Or can you check your My Account's Transaction log to confirm when was the last payment date?
05-29-2022 08:19 PM - edited 05-29-2022 08:20 PM
If your renewal date is today and you are on autopay and you have no services it is probably due to an autopay failure. If this is the case, log into self service and go to the Payment tab and make a payment for the cost of your plan. Choose other from the drop down menu when making the payment.Choose reactivate if there is that option,
05-29-2022 08:18 PM
@Treicpe hi was today your renewal date? are you on autopay ?
05-29-2022 08:17 PM
Do you know when your last renewal date was? If your renewal was supposed to happen today and payment failed, that woild explain service not working.
