Phone number attached to my account
BJaynanoose1
My grandson’s phone number is not working. When I call it’s says invalid U.S. number
Hi @BJaynanoose1 it is a common PM glitch
Make sure the account is active.   chexk using Incognito/Private/secret  mode.  There was another member with that error, and turn out the account was not renewed properly, just PM gave a weird and unrelated recording
If the account is active, Please submit ticket to CS agent at:   https://widget.telus.tiia.ai/publicmobile/publicmobile.html
First type Contact,
from the list of , choose "Other"
DDM69
@BJaynanoose1
Please send a private message to the Customer Support Agent by clicking here
@BJaynanoose1  Each account can only have 1 phone number and it’s own unique email
hairbag1
@BJaynanoose1
have you called that number in the past ? Try dialing again, but dial 1 ahead of area code.
