Pausing my phone plan
09-17-2024
09:38 PM
09-18-2024
11:10 AM
computergeek541
10-02-2024 09:06 PM
@StellaXu hi, unfortunately, we don't know for sure how long you have before it will be voided.
As previously indicated, you can message support and ask. Hopefully they will be able to give you a definitive answer.
10-01-2024 10:37 PM
@abs0Lut wrote:It won't start till you activate, any problems just contact them via live chat
Unfortunately, Public Mobile does not offer any form of live chat.
10-01-2024 06:46 PM
yes , you can hold on to your unactivated plan and start it when you want
Within a month is certainly ok. Should be ok if it is longer. But if you not plan to activate for even longer, you should ak for refund while you still can. please message support if you are going to do that
10-01-2024 06:43 PM
Hi Sansan, I paid for the plan already but I haven’t activated it. Do you know if I can use the plan at a later time and I won’t have to pay again?
09-17-2024 11:22 PM
09-17-2024 09:42 PM
@StellaXu the plan plan will start when you actually activate the sim card.
You should be fine for a few weeks.
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
