2 hours ago
Hello, wondering if the Samsung Galaxy Folder 1 is compatible with Public Mobile.
an hour ago
hi @LoDeL1
Galaxy folder 1 has only the compatible bands on PM's 3G network. So, you will be only using 3G voice (which is ok, many PM subscribers are still using 3G voice) and using 3G for data (which hopefully ok as this phone shouldn't be using much data as it is on older Android)
2 hours ago
I have used the Samsung Galaxy Fold 3 and no problems.
2 hours ago
@LoDeL1 Yes it is
