Transfer Phone number
adoromal93
I need transferring my existing phone number from old service provider to public mobile. I can send text message & call but I can’t receive from others. Your help is greatly appreciated.
1 REPLY 1
@adoromal93
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
