a month ago
I was sent an esim upon subscribing to Public Mobile but it turned out to be incompatible with my Samsung S20. Now, I can't swap the Sim to a physical card because they keep sending 2-step authentication codes to the phone number that doesn't work. Can"t call in, can't call out, can't text or use mobile data - otherwise, a good experience so far (sarcasm) . . . .
a month ago
I have checked and messaged numerous times, no response yet
a month ago
@DJL6666666666 wrote:I am currently waiting for their response, it has been almost 2 days now
maybe agent replied already. Please check here
https://expert-messaging.publicmobile.ca
if no response yet, message there for update
a month ago
lotsa luck !! Even if the phone number hasn't worked since "activation" you will be on their schedule to reply - I am currently waiting for their response, it has been almost 2 days now
a month ago
Created an account, paid for a plan, transferred my number from SaskTel, still no working phone. The esim that was sent is "not compatible" with my model if phone. Submitted a ticket but it has now been 40 hours and no resolution - they keep sending 2-step authentication notices to the number that does not work
