03-17-2023
08:56 PM
03-18-2023
03:31 PM
Dunkman
Hi,
In my friends phone he is getting trouble to make Out going and incoming call. We try to diagnose and turn on flight mode on and off, network selection manual public mobile. It's work for one day and now again giving issue to make call. Text messages incoming and outgoing working fine. We have tried his sim card with another phone but issue still persist.
Please let me know if I buy new sim card then how to transfer number to old sim to new sim card.
Your help would be appreciated.
Thanks.
03-17-2023 10:19 PM
Ticket has been raised.
Ticket reference number: 33111-520
03-17-2023 10:18 PM
Tried PM sim card with another cellphone worked but only one day after same issue persist.
03-17-2023 09:28 PM
I have tried, all solutions whatever you provided, however sim not working with another phone as well.
03-17-2023 09:26 PM
@Vimalkumar wrote:Tried already, even change the phone but issue still persist
@Vimalkumar if changing phone does not work, start with open ticket with PM support. Go through all the troubleshooting steps with them first. They can reprovision the sim on the system and that might resolve the problem
If that stil does not work, ask them about sim changing and ask if they can reimburse the cost of the sim card
03-17-2023 09:25 PM
03-17-2023 09:24 PM
Changes are it is not the sim card. Sim card rarely fail, if it fails, you won't connect to the network at all and you won't have Text working
It is likely a phone issue or account
did you try to Reset All networks?
also did you try in different area and if voice calls work when you move around?
try to change the Preferred network to 3G only and see if it helps.
Or change it back to Automatic and enable VoLTE (VoLTE might or might not work as PM is in the process of enabling customers on VoLTE and not everyone is enabled yet)
If possible, test the PM sim card in another phone. This would force a sim re-provisioning and it could resolve your problem
Let us know how it goes
03-17-2023 09:06 PM
Chances it is not the SIM but the phone settings.
Go to Settings and reset the Network but they need to re-enter the home wifi password.
03-17-2023 09:00 PM
@Vimalkumar You tried to reset network setting ? If you get a new SIM card you don’t activate it or port number you SIM card swap it in my account using computer only from the profile tab
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
03-17-2023 08:59 PM
@Vimalkumar , please use the chatbot link to initiate a support ticket. Hopefully an account reset will clear any issues with calling.
