Call connection is delayed when I answer a call.
Peajayz
When I answer an incoming call, it seems to take a few more seconds delay before the caller can hear me saying "hello, hello?".  Callers say it is still ringing for them when I first answer.  Any ideas?
2 REPLIES 2
Peajayz
Network reset - done.  Reboot - done.  Pixel 9a is VoLTE compatible.  I've put in a service ticket so will see if issues persist!   Thanks @Dunkman for the help. 🙂
Dunkman
@Peajayz
Might want to try a simple reboot of your phone.  Or network reset of phone.
Which model phone are you using?  Is it VoLTE compatible with PM network?  That would be important for better voice calling.
https://www.publicmobile.ca/en/get-help/articles/volte
