03-17-2023 08:07 PM
My job has me outdoors in the States where I need a last second phone call that the company will reimburse me for the expenses. So cost is not an issue, but if I understand it correctly you cannot purchase anything last second with Public Mobile without having internet (which if I had internet in the States I would just call over the internet and this wouldn't be required). I cannot purchase an add on prior as the company will only reimburse if a phone call was nessessary not possible.
03-17-2023 11:25 PM
For what you want you need to move to a post-paid carrier that has a roam like home plan whereby you only get billed the daily rate if you use it that day. That's not possible on Public Mobile. Either buy the roaming package ahead of time or when you need it, but you can't be on standby to have a roaming add on automatically added.
03-17-2023 10:58 PM
@bkenney wrote:If I buy the us add on doesn't it expire in 15 days? That would not work as I will find out I need to make a phone call 39 seconds from making the phone call. I need a solution where it's more pay per use not wasted after 15 days
@bkenney there is no need to be upset at Public Mobile. PM is a tier 3 providers and they provide service different from it's Tier 1 or 2 brothers (Telus and Koodo). If you need some pay-per-use roaming service, you need another provider. Check Koodo or Telus and they might be something best for your situation.
03-17-2023 10:54 PM
This sounds like a viable solution. If connected to T mobile I can use a pin after filing that number to enable an add on, thank you!
03-17-2023 10:52 PM
That sounds to me like public mobile is completely useless. If I had wifi once I figured out I needed to make the call I wouldn't need this add on to begin with. I would need to make a call without wifi and not have an add on expire due to inactivity
03-17-2023 10:50 PM
03-17-2023 10:47 PM
The typical fight where they won't provide a phone yet it's extremely beneficial to have one
03-17-2023 08:29 PM - edited 03-17-2023 08:37 PM
Disclaimer: I have not used this myself recently, so take it with a grain of salt and do your own tests in a non-crucial setting?
Calling 1-855-4PUBLIC gives you access to your IVR system the same way 611 does in Canada. You'll need your account PIN to access most features.
You can buy add-ons, including US roaming add-ons, by going through the prompts in the menu.
You'll need a valid credit card registered in your account or have enough available funds to buy the add-on (you could add vouchers trough the IVR as well, but you can't buy them in physical stores in the US, so would need internet access to buy them online?)
Edit: Hm, not sure on all the details, but if my employer expects me to make roaming calls, shouldn't they set me up with a phone plan that allows me to do that?
@dust2dust I tend to forget the online vouchers, thanks for the reminder!
03-17-2023 08:28 PM
Most businesses offer Roaming on their business cell carrier.
If not, ask your manager whether you can purchase a local SIM from Mint or Tello mobile.
03-17-2023 08:27 PM - edited 03-17-2023 08:32 PM
Is this another thread?
Another way to buy add-ons is through 611 or the toll free number. If you're connected to T-Mobile and you have reception then 611 and 1-855-4pu-blic work without any add-on. Then you can deposit money with your 4 digit pin from your registered credit card. Or buy a voucher online and enter it here without a 4 digit pin. Then you can buy a roaming add-on.
Adding - right @wetcoaster you need the pin to buy the add-on. And you can buy the vouchers online.
03-17-2023 08:24 PM - edited 03-17-2023 08:27 PM
Yup, you need to purchase an add-on, @bkenney
You'll need access to self-serve to do this. Try to find a Wi-Fi zone, i guess.
EDIT: which you must have already, as you started this thread online...
03-17-2023 08:19 PM
@bkenney You need to purchase a U.S. roaming add on to use your PM phone in the states sign into your my account and pick the US Add on you like best make sure it’s connected to T mobile and reboot the phone …. If your trying to re buy very same add on you need to wait 12-24 hours after the first one ends only support can apply the very same add on back to back
- Get support by starting a conversation with virtual Chat box /SIMon. Click here
- you can send a private message To CS_Agents by clicking here.
Watch for reply top of page to the
Right ( envelope image )
