Not receiving mms pictures.
Inthecool1
Mms pictures won't download. Can  send and have data. I believe this happened a couple years ago and agent had to reset something. But no able to submit ticket.
Getting the "OOPS" message
12 REPLIES 12
on2wheels
This past weekend I had trouble both sending and receiving MMS messages, did anyone else? I'm wondering if there was a service interruption with Telus in my area of eastern ontario, Ottawa area, or something else with my phone.
Inthecool1
Thanks. Did not have mms settings set up in settings. Those are not on partner' android phone.... That works.
Those settings saved now
@Inthecool1
you can try to Reset all Networks and see if it works
or you can compare the APN settings below, try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
Inthecool1
Tried Google messenger and tried small picture. Pretty sure this happened a couple years ago and Telus had to reset something on their side
@Inthecool1  so you tried Google message?
ask your friend to send you another file, another pic, just jpg and smaller size.  I wonder if it is a size issue.
Inthecool1
Gabe an android. Data on . Have tried other apps for default.
Can send MMS pictures. Just not recieve.
Would love to issue a ticket
@Inthecool1
are you on android or iPhone?
Inthecool1
No cat pictures...
And no luck.
Inthecool1
Yup this post sent with mobile data
Chalupa_Batman
Try going to your network settings and refresh them. Then go into air plane mode and wait 10 seconds and turn off air plane mode. Reboot your phone. Wait 30 seconds and boot it back up. Then give it a try. Just please don't send me any cat pictures. I hate cats. 🙂
@Inthecool1
Make sure your mobile data is turned on
And Android or iPhone?
If Android, try to clear cache and try again .  If still failed, download Google Message and set it as the default messaging app and try again with the new app.
HI @Inthecool1
do you have mobile data enabled?  you need it on to download MMS files
