a month ago
Hi, I've been receiving spam text messages from numbers I don't recognize from another province. How can I block and report them? I've tried the "report junk mail" button but one particular number is messaging me regularly now that's turned into a one way conversation for that person and is turning into harassment.
a month ago
hi @robopizza
try :
Block a specific number:
Open the Messages app
In a conversation, tap the name or number at the top
Tap Info
Scroll down and tap Block this Caller
Block texts from unknown numbers:
Go to Settings > Messages
Scroll to the bottom and tap Filter Unknown Senders
Add all known senders to your contact list
a month ago
Thanks for the replies. I'm using an iphone and don't see any block options.
a month ago - last edited a month ago
@robopizza Depending on your phone and app you are using you block the number. On messages in my Pixel 5 I click on the 3 dots when the message is open and select "Block and report spam:. I won't see messages from them again.
hi @robopizza
you can block the number and the text will go to junk mail
some might also suggest to change phone number, but i don't think it worth the effort. Like junk email or junk mail, you cannot really got rid of it completely
