01-10-2023 10:17 AM - last edited on 01-10-2023 05:19 PM by computergeek541
Hi,
I have tried porting over three phones from Bell to Public and I replied YES to the texts but cannot receive incoming calls.
Please help.
01-10-2023 01:02 PM
Thanks, I did open a ticket with PM
01-10-2023 11:56 AM
@v_bahlca - are these are Bell cell ports or any landlines?
Incoming calls are usually the last to port over.
When the incoming calls stop on the previous provider’s SIM card and/or landline, that is a good indication the port is complete.
If still issues or never replied YES, you may also submit a ticket with Public Mobile representatives (CSA) for help; click this link for issues with transfer/porting of phone numbers over to Public Mobile.
01-10-2023 11:13 AM
Yes, using iPhone. Messages I am receiving are from android phones.
01-10-2023 11:10 AM
01-10-2023 11:07 AM
I switched the service last night.
Funny part is I am receiving SMS messages. But the call is going to voice mail
01-10-2023 11:07 AM
@v_bahlca wrote:Hi, PM account shows my correct number. I will try and shut the phones again for few minutes.
Yes, the call goes to Bell voice mail.
shutting my phone now for 5 min
Hope this works.
Thanks
@v_bahlca if calls still going to Bell VM, that mean Bell has not pass the phone number to Public Mobile yet,
you called the porting support team yet? they will provide you update
01-10-2023 11:04 AM
Hope this works.
Thanks
01-10-2023 10:33 AM
@v_bahlca @When porting to a new carrier it’s important to leave old SIM card in to replay yes to the text as you indicated you have but it also needs to be done within 90 mins of receiving the Confirmation text also
01-10-2023 10:32 AM
@v_bahlca you ported over 3 phones form bell to PM, none of them can receive incoming calls?
When did you reply YES? usually it takes 30 mins to 4 hours for the port to complete
There is a number to call to talk to live support, they can provide update or re-trigger the process for you if needed. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it sorted out
01-10-2023 10:22 AM
If you just ported from Bell, there is another 90 minutes to complete the porting process so you Bell SIM will continue to work until porting is completed.
Once it stops working then POWER OFF (not turning off the screen or restart the phone) your phone then swap the Bell SIM with the PM SIM.
01-10-2023 10:22 AM
Log in to your PM account and see what number PM has for you.
Does ANY of 3 ported numbers/phone receive calls on expected - transferred numbers?
Did you try to reboot phone - turn it off, wait a bit, turn it on?
When you call your Bell number - where it goes? Still to Bell (voice mail)?
01-10-2023 10:22 AM
Hi, yes few times.
01-10-2023 10:18 AM
@v_bahlca @Have you rebooted the phone yet ?
