Not able to make or receive calls
Cardy
Does anybody else have this issue?
10 REPLIES 10
@Cardy...
good to hear it;s working again. So what did you do to get it going ?
Cardy
Thank you all for your tips and suggestions.  It is working now. 😊
Cardy
Thanks.  It is working now.  I appreciate all the helpful tips and comments.
@Cardy Seems like you have done all the basic troubleshooting. If incoming/outgoing calls are still not working, you might wanna reach out to PM CS_Agent.
Here’s when and how to contact our Customer Support Agents:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
Cardy
Thanks. Tried data without wifi and texts are okay, no calls though.
Cardy
Thanks. Texts are working and Internet too, just not incoming or outgoing calls. Calls were working fine this morning then stopped late afternoon.
Cardy
Thank you, yes I did all that, however it did not solve this issue.
hairbag1
Is text / data still function properly...(not on wifi) ?
Yummy
When did you signed up with PM?
Did you port your number?
Were you Ever able to make and receive calls?
How about other services? SMS/Internet? Do they work?
JK8
@Cardy
Are you a new customer?
Have you tried rebooting, resetting network settings, or resetting your SIM card? Is your account Active?
