Dead loop between rogers and public mobile after transfer
sha2
So, I initiated my transfer from rogers to public mobile last week. After that, I've never received a text message confirming transfer. Instead,  the data works, I can call out, but was not able to receive calls, not able to send or receive messages. I submitted a ticket, public mobile agent asked me to call rogers to manually approve. I called rogers. Rogers agent said ok approved please call public mobile again and they will be able to transferr your number now. I contacted public mobile agent again, same agent told me they have resubmitted a ticket and again ask me to wait for a text message to reply otherwise  need to call rogers to manually approve? I've already said, I cannot receive any texts since last week. My phone shows that my service now is with public mobile. What can I do?
Dunkman
@sha2
Most Roger mobile numbers take a few hours to be ported over.  Was the number a VOIP line?
Did you talk with a live person from the Telus team porting line?  If not, try again during daytime hours since that team does not work in evenings and overnight.
sha2
Thanks I called the number. Says my number tranfsrr is in progress and will let me know via sms. This is so stupid it's been a week and I cannot receive text. I tried another option technician support and ask to connect to an agent It says goodbye and then hangup
@sha2 wrote:
Thanks. Where is my community inbox? I didnt see any messsage or I didn't know where to find it
@sha2
sha2
slusagm
@sha2
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
