01-21-2023 02:37 PM
I have tried the instructions from the community on how to register new sim. From the profile menu I went to the activate new sim option and entered the new sim card number and hit Save. However the moment I hit save it just refreshes with 0000 and the new sim card number is not reflected on the account. Can I reach public mobile customer service? I paid for the plan and not able to use it because of this technical glitch.
01-21-2023 07:14 PM
This worked after two hours. Thank you for the support.
01-21-2023 07:13 PM
Thank you. This seems to have been the solution. Two hours after doing this I have network. 🙂
01-21-2023 05:13 PM - edited 01-21-2023 05:14 PM
Have you rebooted the phone? Either way power off the phone and remove the Sim card. If possible put it in another device and reboot. Check for service. Power off. Remove Sim card. ( If you can't put it in another device just leave it out of your phone for at least 10 minutes. Reseat the Sim card back in your phone and power back on. Check for service.
What is the reason for changing the Sim card originally? If it was a provisioning issue and your account has not been reset and reprovisioning by customer support has not been attempted you will experience a similar problem with the new Sim card. You will need to contact customer support. Have them first confirm you have successfully swapped Sim cards (the message you recieved indicates that you have done so) then ask them to reset your account and reprovision your Sim card.
01-21-2023 03:57 PM
Once you updated the number, and submit, and log out of the self-serve site, did you try the SIM in the device to see if (by any chance) it may have associated with the account?
01-21-2023 03:21 PM
@Sreddy wrote:Followed this exact step and clicked on save changes. There was a message saying the number is changed. However, it still shows the old SIM and I do not have service.
@Sreddy you were using a mobile device ?
please do it again using laptop or desktop computer. It is a known glitch the page is accessed via mobile devices like phone or tablet. Please try it again on a computer and it will work without problem
01-21-2023 03:17 PM
01-21-2023 03:16 PM
Tried this on safari in private mode. Did not work. A message did pop up that the sim number is changed. However, I still see the same old SIM number on the account and also do not have service. Not sure if there is a wait involved before this is processed.
01-21-2023 02:49 PM
@hairbag1 Just found that from your earlier post to give to op
01-21-2023 02:48 PM
01-21-2023 02:43 PM
@Sreddy wrote:I have tried the instructions from the community on how to register new sim. From the profile menu I went to the activate new sim option and entered the new sim card number and hit Save. However the moment I hit save it just refreshes with 0000 and the new sim card number is not reflected on the account. Can I reach public mobile customer service? I paid for the plan and not able to use it because of this technical glitch.
Since PM website has caches issue, so clear caches , cookies then using computer and private or incognito mode browser to login. For some mysteriously reasons, mobile device some times hard to login, so don't use mobile device to login.
Follow above method try login again.
If still doesn't work, wait a couple minutes, login again.
Or chat with Simon for help, if Simon can’t help, he would let you submit a ticket.
https://www.publicmobile.ca/en/on/get-help
01-21-2023 02:38 PM - edited 01-21-2023 02:59 PM
@Sreddy Don’t activate it … use a computer and swap sim
edit support
edit visual for ya here courtesy of @hairbag1
SIM SWAPPING
Edit if this pic is what ultimately helped you give the accept solution to @hairbag1 please
