07-23-2021 11:58 AM - edited 01-06-2022 02:52 AM
Hey folks,
Looking to use PublicMobile, and was wanting to use a Nokia 800 Tough for my phone. I was wondering if anyone has done this before, as it says that the Nokia 800 Tough does not work on CDMA networks. I am not the most savvy with cellular technology, and wanted to make sure this would work before ordering the phone. I was looking to order this one from this link: https://www.amazon.ca/Nokia-2100mAh-Rugged-Factory-Unlocked/dp/B07X63JCWT (not sure if it matters where I get it from, again just wanting clarification to make sure this would work). Any help and clarification on if I would be able to do this with public mobile would be great!
Thanks so much in advance!
07-24-2021 12:20 AM
I don't recommend the sonim series of tough phones. They did not pass the bf test....barely made it 4 months.....
07-23-2021 11:29 PM
@LurganIeUk @AE_Collector maybe you are confusing WCDMA with CDMA. They are completely different technologies, and incompatible with one another.
@Anonymous @softech thanks for the kind words!
07-23-2021 01:17 PM
The TELUS network hasn’t been CDMA for years… and years now.
AE_Collector
07-23-2021 12:41 PM - edited 07-23-2021 12:42 PM
@Anonymous .. yup.. my comment earlier wasn't targeting to your comment 🤣
and yes.. I trust sheytoon fully and learned a lot from him.. he is the PMikipedia here.. if he said yes.. i will go out and put it without a 2nd thought.
(hey.. same goes to your comment.. i trust you too.. if you said yes.. I will buy 🙂 )
07-23-2021 12:37 PM
@softech : Of course we need to be sure. But when someone like sheytoon steps in - that becomes the mic drop. He opines that the phone would not be entirely ideal but that it could barely work. He suggests continuing shopping. I would listen. Note: I'm not doing the mic dropping here. If sheytoon had not replied I would have said as much without the mic.
Terminology gets mixed up out in the wilds. There's a separation between CDMA and others. Others start with GSM. If you see "doesn't work with CDMA" then you know you can dig deeper.
07-23-2021 12:28 PM
honest, we have to be extra careful in concluding if a phone will work or not on PM. Someone might go out and order a new phone for couple hundred bucks based on our comment.. 🙂
07-23-2021 12:26 PM - edited 07-23-2021 12:31 PM
@Anonymous .. you forgot to tag him with @ 😀
07-23-2021 12:25 PM
So let me introduce to you
The one and only ...sheytoon.
Our resident expert.
07-23-2021 12:20 PM - edited 07-23-2021 12:25 PM
@sheytoon wrote:Assuming it's this version:
https://www.nokia.com/phones/en_int/nokia-800-tough/specs
It is not ideal in terms of band support. It's missing 3G WCDMA B2 (1900) and LTE B2, 4, 12.
Network bands (LTE):(excluding USA and Latin America) 1, 3, 5, 7, 8, 20, 28, 38/41 (120MHz), 39, 40;
(Europe) 1, 3, 5, 7, 8, 20
Network bands (WCDMA):(excluding USA and Latin America) 1, 5, 8;
(Europe) 1, 5, 8
No assuming....look at what @zacforan said "the Nokia 800 Tough does not work on CDMA networks"
And look at what the ad says.....
07-23-2021 12:19 PM - edited 07-23-2021 12:24 PM
@Anonymous wrote:yes will working with public mobile
visit Here to see your phone
@zacforan says that the Nokia 800 Tough does not work on CDMA networks...so it is GSM.
And when Googling Telus they say:
No GSM device will work on the Telus network. Only Rogers. GSM also has horrible speed and reception as it's decades old.
So as @softech says...it WON'T work!!
07-23-2021 12:16 PM - edited 07-23-2021 12:18 PM
(Europe) 1, 5, 8
07-23-2021 12:09 PM
NO, it won't work. It is for European and Asian market which use different frequencies.
07-23-2021 12:06 PM
07-23-2021 12:05 PM - edited 07-23-2021 12:06 PM
PM uses these bands and does not use CDMA.
Public Mobile frequency
3G HSPA+ B2(1900), B5(850) (Fallback for calls & 3G data)
LTE B2 (1900)
LTE B4 (1700/2100 AWS 1)
LTE B5 (850)
LTE B7 (2600)
LTE B12(700)
LTE B13(700)
LTE B17(700)
LTE B29(700)
