04-19-2024 11:19 AM - last edited on 04-20-2024 02:48 AM by computergeek541
I've only seen this question before they released a 2023 version. If I were to purchase this from USA, would it work here in Canada with public mobile?
04-19-2024 01:01 PM
04-19-2024 11:41 AM
@Clue1ess It's whether a phone is VoLTE enabled by Public Mobile that matters, not whether the phone itself is VoLTE capable. It's possible a phone not on PM's VoLTE list might work but it's a long shot gamble. You can check the list here (disregard that the article implies 3G is still available in the USA, it is not although where it still exists a non-VoLTE phone can still use T-Mobile's 2G network, which is also being shut down).
04-19-2024 11:34 AM
So I tried the website and it says the 105 doesn't support 4g ... But then in 2023 they released a 4G LTE so I don't imagine it's accurate with the updated version right?
04-19-2024 11:33 AM
So on the American Amazon it says 4G voLTE. It does say GSM supported, not CDMA. I don't know if that has anything to do with it, I'm truly clueless.
04-19-2024 11:28 AM
@Clue1ess Disregarding other possible compatibilities, there are no Nokia phones listed on Public Mobile's VoLTE enabled list so it's not guaranteed to work where there's no 3G. Since you're getting the phone from the US does that mean you plan to travel in the US? If so you will have problems with voice calls since there is no more 3G in the US.
04-19-2024 11:23 AM - edited 04-19-2024 11:23 AM
It should if it handles PM frequencies.
https://www.publicmobile.ca/en/on/get-help/articles/check-your-phones-compatibility
