04-18-2024
05:50 PM
04-20-2024
02:47 AM
computergeek541
Hello,
My husband and I have Canada/ USA talk and text subscriptions. We can call each other but cannot text each other. Is there a setting that has to be activated for texting to work?
Thanks!
Jan
04-19-2024 01:12 PM
@Bestlife - Your welcome. 🙃
04-19-2024 11:22 AM
Turning on roaming data worked. Thanks so much for your help!!!
04-18-2024 05:55 PM - edited 04-18-2024 05:56 PM
@Bestlife - Do you have the Canada-US plan or roaming talk / text ( with Addable data)?
For Canada-US plans - please try turning on Data Roaming.
For Talk / Text 15 day add-ons please turn off RCS or iMessage on both devices to start texting each other.
If you are using the Talk / Text / 3GB 15 day add-on please make sure data roaming is on.
You can also try connecting to T-Mobile or AT&T
04-18-2024 05:53 PM
Hey @Bestlife
Go into your settings, network settings and turn off automatic and pick T-Mobile then reboot. SHould work just fine as I was in the US 2 weeks ago.
