Dumb phone Can US
JFBR
I’m looking to switch to a dumb phone like cats22 or Nokia 2780. Does anyone use any of these phones with public? If so does it enable volte so you can use in Canada and US?
JFBR
Hi do you know where I can find the white list. I want a basic flip I can use that has maps and can call in US and Canada
@JFBR
It sounds like you are looking for a flip phone that is VoLTE compatible.
There seems to be a few available on Amazon.
https://www.amazon.ca/s/?ie=UTF8&keywords=4g+volte+flip+phone&index=aps&tag=h0a61-20&ref=pd_sl_99pl3...
@JFBR
both CAT22 and Nokia 2780 work with PM at the moment
https://productioncommunity.publicmobile.ca/t5/Get-Support/CAT-S22-compatibility/m-p/1349496
https://productioncommunity.publicmobile.ca/t5/Get-Support/Nokia-2780-MMS-APN-Settings/m-p/1342164
But they are both not on PM's VoLTE whitelist.  What it means is that unless PM add them to the list, their voice calls will not work once 3G is decommissioned.
If you have the phone with you now, it's ok to use.  But If you are buying this phone, I would avoid.
