Changing physical address
Codyash
I'm trying to update my physical address the one in my account profile is not the right one anymore  same city and province just different street address   the system  just keeps saying it is invalid  it is not !!! Help please
7 REPLIES 7
@Codyash wrote:
Yes my address has to be right because I'm ordering a new sim card and it cannot be sent to a po box with canada post on strike  so public mobile says I have to have a physical address  for shipping but the system will not let me add my physicsl address it is driving me crazy!!!!!
Is there a Mobile Klinik in your area ...they have the Public Mobile sims available.
Codyash
Tried that too   all those things  just going to give up  and say goodbye to public mobile
Codyash
I tried no solution from them either  may have to forget public mobile and sign with a different carrier one that actually let's you talk to an agent
Codyash
hairbag1
@Codyash
the address isn't verified by Public Mobile or anyone else...so having the exact address isn't critical.
hi @Codyash
if the system is unable to take your new address, ask PM support agent to update it for you
ubmit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
Did you type the address slowly and see if the Auto lookup cam pickup the address?
Or PM can help you to update the address on the system directly .  Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
