Us canada plan
Nbbb
Hi
I am on the new us canada plan and am in Florida now. I can send and receive texts no problem but can't send or receive pictures. I have the Nokia 6.1 and phone is connected to mobile here
Any suggestions?
Thanks
@Nbbb wrote:
It worked with the all caps
Do I have to change anything when back in Canada?
@Nbbb
Glad it worked.  As long as your saved the APN settings, you should be fine when you get back to Canada.
Nbbb
@Nbbb
Make sure that there are no typos.
You can also try
APN: SP.MB.COM
(all caps)
Other customers had to completely create a new APN Setting (instead up updating)
Nbbb
Settings changed. "Trouble sending. Retrying. Check options"
Tried resend now..still no go
Nbbb
Talk and data work fine.
I will try changing settings.
Dunkman
@Nbbb
Is talk and data working fine?
Issues with MMS (Picture) texting with some older android phones.
There was an recent announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
You could try to adjust your APN settings:
You could try setting your APN settings to following:
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or             default,mms,agps,supl,fota,hipri
