Data
Mara4
Have a data plan. Lots of data left. Can't access the Internet without wifi. Have checked the APN settings. Reset the network still not working. iPhone se
10 REPLIES 10
@Chalupa_Batman that is still not true.
The APN settings there only manages hotspot sharing.  If that screen has the wrong entry, data on your phone will still  work, but just you cannot successfully share your hotspot.
However, with the correct Carrier Profile, usually even you tweak the APN on that sceen, it will change it back to the correct APN, depends on the setup
thanks @softech for your confirmation and explanation, it really help people on thos community to have better understanding on how iPhone works
@softech wrote:
@Chalupa_Batman The APN settings on iPhine is under Mobile Hotspot and it is not used for regular data access, it is only meant to setup for Mobile sharing
APN settings for  regular data is managed by Carrier Profile.  It is fully locked down by Apple  and there is no way for regular users to modify it
Some parts of that are correct, as the part where iPhone users can't access it. However, APN settings are meant for both data and hotspot. If the APN settings are incorrect, you wouldn't have data.
hi @Chalupa_Batman
you might not know iPhone well.
on an iPhone, the APN settings are locked and controlled by the carrier profile. You normally cannot edit APN unless the carrier explicitly allows it, and Public Mobile does not allow any modifications
And if you have the correct Carrier profile, you can update the "APN" you see on your iPhone but it still won't affect your data access, as that is not the screen that controls it
@hTideGnow wrote:
hi @Mara4
the APN settings you see on iPhone won't help for data access, it is for hotspot setup
 Actually @hTideGnow , APN settings are meant for data usage, including hotspot settings. The APN settings are like a connecting bridge between a persons mobile device and Public Mobile's network (Data). If a persons APN settings are incorrect, then they won't have data access. As you've mentioned, resetting the Network Settings and rebooting the iPhone SE will reset the APN settings that should be there.
hi @Mara4
For iPhone, make sure you have the latest iOS and have the latest Carrier Profile.  Then try Reset network settings once more
also, check then Telus Service Status map
https://www.telus.com/en/ab/outages
but if same, ask PM agent to refresh the account.   Please submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
Chalupa_Batman
Hello @Mara4
This has been an ongoing issue for a few weeks. This suggested has helped a few so far.
Turn your phone into Airplane mode for a full 10 to 15 minutes. Then, turn the phone off for a full 5-10 minutes. Reboot the phone, turn airplane mode off, this will reset your connection to Public Mobile.
hairbag1
@Mara4
using the mobile app, log in to your Public Mobile account you should see Usage Breakdown...tap it to see status of your plan including data and add-ons in your account. Is it possible you've used up your data allotment until next regular plan renewal ?
slusagm
check if our data is turned on .
also, check if you have mobile data limit enabled, it could be blocking it
but if data issue persists, ask PM to check and reprovision the account on the system
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
