No service zone
12-26-2022 04:33 AM
Hello,
I don’t get any service in my neighborhood//home of South Surrey in BC. Is there a workaround? I’m a healthcare worker who is on call for hospitals. Thank you.
Service
12-26-2022 07:34 PM
@Kokoeye403 I was in Surrey area last night and I had reception. Did it just happen today?
working now?
12-26-2022 12:26 PM
@Kokoeye403 There was a outage notice for wide area in BC on Telus status page yesterday (actually it was since Dec 23). But it is now gone, so I will assume issue is all resolved.
so, try reboot your phone once and see if it works better now. And if you are going out today, try the phone in different area and see if you see any difference
12-26-2022 12:23 PM - edited 12-26-2022 12:24 PM
Are you new to Public Mobile and/or is this a new issue? I find coverage in South Surrey to generally be very good, but it's never guaranteed indoors. Public Mobile uses the Telus network, so if you've recently moved from Rogers/Fido/Chatr you may not be getting as good of signal penetration through buildings than you did with your previous provider. WiFi calling would be a great alternative, but as a budget carrier Public Mobile doesn't offer that. You could look at buying a signal booster system for your house, but it's not cheap.
12-26-2022 10:49 AM
Always - map says I have coverage. I’ll submit a ticket. Thank you for your help.
12-26-2022 10:48 AM
Thank you. Map says there is coverage. It’s just at my house I can’t get the phone to dial in or out! Restarting the phone didn’t work so far. Will submit ticket. Thanks for your help!!
12-26-2022 10:20 AM
Sometimes I don't get service and when I restart my iPhone, it works again. Also sometimes if your phone is exposed to cold weather for a long time, it might lose the signal. If it's a temporary issue, try restarting, otherwise, check the coverage map and file a ticket with SIMon.
12-26-2022 07:57 AM
Is it possible that your device is attempting to connect to US Networks, if you are close to the border at the time of these service issues?
To ensure this is not occurring, under your network connections remove the "auto" setting and manually choose Public Mobile as your network.
12-26-2022 07:52 AM
I haven't experienced any issues when I'm in the South Surrey/white rock area. what's the make and model of the device? what area of South Surrey?
12-26-2022 06:57 AM
@Kokoeye403 wrote:Hello,
It's temporary or always ?
Check PM service coverage map for your location:
https://www.publicmobile.ca/en/on/coverage?gclid=CLuo4c39yNQCFQQvaQodeZEC0g
12-26-2022 05:09 AM
Is it always like that but it's fine everywhere else? The only workaround is to have another phone number and forward calls to that number but you have to do that when you have Public Mobile signal. It could be a temp network problem but if it's always like that, you need to try Rogers or Freedom.
