10-12-2021 04:18 PM - edited 01-06-2022 03:31 AM
Hello,
My phone has been giving me trouble and I'm looking for suggestions how to fix it. I have a Samsung Galaxy S8.
Since yesterday, my phone continues to go 'in and out of service'. Initially I thought the network itself was having issues, but it's clearly just me as other family members who use Public Mobile don't have the same problem. I am in town at home and normally have no problem getting signal or service, so it's not my location.
I've swapped SIM cards with my wife's phone and confirmed that the SIM card isn't the problem.
I've rebooted the phone and put it in and out of airplane mode numerous times.
I've checked the SIM card and made sure it's seated correctly numerous times.
I've tried to manually select network operators, but Public Mobile usually listed.
I've even done a factory reset with still no luck.
The strangest thing, is that it's not just 'no service' all the time. It seems to come and go sporadically and I'll get a bunch of messages sent an hour previously.
Other ideas?
Thanks,
Rob.
10-13-2021 06:28 AM
You have done some good trouble shooting -- even a factory reset!?
Have you tried your wife's SIM into your device (good test, especially if she is with Public Mobile).
If it works, then I would check two things:
1. Log into your Self Serve and confirm the last 4 digits of your SIM card match the numbers listed there, under 'Change Sim Card'.
If they match - great!
If they do not match, list your phone into lost/stolen status and contact CSA to let them know.
2. Probably not the case, but just to make sure, check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
10-12-2021 11:55 PM
It could simply be that one of the frequencies/bands your phone was relying on has been temporarily shut down on the tower nearest to you, or possibly permanently if it has been refarmed for LTE use.
For example, Telus, at least in Manitoba, has recently relinquished their 850Mhz 3G band for more LTE coverage, leaving 3G service only operating in the 1900Mhz band, which could have less range, especially in basements, etc...
Maybe your wife's phone supports some additional band that yours doesn't. It is hard to say exactly unless you start installing diagnostic apps that can show you for sure what frequencies/bands each phone is actually using... for LTE there's a half dozen at least in use in Canada...
10-12-2021 06:18 PM
@alenadevlin wrote:
To my understanding OP already confirmed that his SIM works perfectly in wife's phone.
Did you try wife's SIM in Your phone? Do you still get intermittent service? If yes, maybe your phone is slowly dying 😞
Beside cleaning SIM contacts on SIM card and in the phone you might try to air blow SIM slot in your phone (those can with air...) to remove potential tiny debris. Do not blow by mouth as you might introduce moisture and I would not stick anything in SIM slot not to damage contacts.
10-12-2021 04:45 PM
Additionally to @hTideGnow 's advice check your sim card slot for dirt or debris and gently clean your sim card with a cotton swab and a little isopropyl alcohol.
Switching to the 3G network is unlikely to help if text messaging is also affected as texting works on both the 3G and 4G LTE network unlike calling which uses 3G only.
10-12-2021 04:37 PM
@alenadevlin It could be a SIM contact issue, if so, it's more hardware issue.
Any chance you have another SIM card from another provider? It would be a good test to confirm if it is the hardware. Some people might put a tab on the back to make sure it has a tight contact between the SIM and the phone (be careful not too thick and SIM might got stuck)
10-12-2021 04:29 PM
Hey Rob,
Another troubleshooting step is to put someone else's SIM (friend/family) in your phone to see if it works well. If it doesn't, then you'll know the problem lies with your phone.
10-12-2021 04:27 PM - edited 10-12-2021 04:28 PM
visit to Coverage Map Here .
or Here
and check out TELUS Service Status outage
can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone..
and can you try your SIM card in another device to test your SIM card,
and if still not fix it you Have To Submit a Ticket To Contact Customer Support Agent by CS_Agent ,
Explain your issue to they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
Good Luck...
10-12-2021 04:23 PM - edited 10-12-2021 04:24 PM
Try manually selecting 3G.
10-12-2021 04:19 PM
I live in Powell River, B.C. if that matters.
Rob
