No mid tier plans
CheddarMom
I have the $15 plan and I looked to see what plans are available to me and the cheapest is $34? That’s a huge jump! There’s nothing in between anymore?
HI @CheddarMom
they have in-between plan now.  PM just came out with $21 1GB 4G speed plan.  Check your My Account's Change Subscription and you will see that
Y4J259
Typical of PM right now, trying to force everyone to move up to higher paying plans.
AK32
You can message a CS Agent on here and ask if you can get one of the new activation prices applied to your account. They may or may not do it for you. Otherwise i would check back every so often because they used to have a $25 plan that they must have recently changed.
turtleTurtle
Check back often if you are looking to upgrade. They are always changing. I see that today the $15 plan is for new activation only. Last week the $15 and $29 plan was available for everyone.
Some people have had luck messaging cs to get a plan for new activation only, but hit and miss with that.
So if you are looking to switch I would say keep checking back and wait for something you like to become available.
