No data after paying 4G service
HL78
I purchased 3G plan for 2 months, no data could be used after leaving office and home where there had wifi. Then I paid for 4G 2 days ago, still no data when I went out from home.
hycm53
@HL78 You need turn on cellular data on.
dabr
@HL78   Do you have the correct APN settings for your phone?  Here's couple of links to check for the APN:
https://www.publicmobile.ca/get-help/articles/set-up-data-on-an-android-phone
https://www.publicmobile.ca/get-help/articles/set-up-data-on-an-iphone
@HL78 this happened to another user today, he got it resolved after opened ticket with PM and had them to reset on the system to clear it up
https://productioncommunity.publicmobile.ca/t5/Get-Support/Switched-plan-and-now-nothing/m-p/893928/...
But first try a reboot and see if it works
If not,  please open ticket
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
DDM69
What type of device are you using?
What plan do you have?
Do you have cellular data turned on?
