11-25-2024
03:45 PM
11-25-2024
05:14 PM
computergeek541
New user on Public.
Esim did not activate for me. Purchased a second one and it also did not work. Data shows as SOS.
Purchased a physical sim. Still SOS.
Have restarted phone XR, checked settings, tried reaching out to the chat agents, and still no service.
Checked Primary and secondary settings and no luck.
Any one else having this issue and not get ANY help?
What is wrong with it?
11-25-2024 03:50 PM
Hi! yes i did update the sim card from esim to physical and can see the physical sm card showing on my profile now. still showing SOS
11-25-2024 03:49 PM
Since you submitted a ticket to a CS_Agent. You will have to wait for their reply. Keep an eye on your avatar top right and under Messages. Depending on how busy they are. It may take up to 4 hours.
11-25-2024 03:48 PM
11-25-2024 03:47 PM
@FLCH Sounds like account set up issue no worries support can help
11-25-2024 03:47 PM - edited 11-25-2024 03:47 PM
did you update the sim card number for the physical sim ?
anyway, ask PM to check . You cannot open Chatbot ticket now, so message them using this link:
