11-25-2024 06:17 PM
I need to get a message to access my bank, and I have no service despite having roaming on?
11-25-2024 06:21 PM
@mesopotamian Then that’s the issues PM only has roaming in the U.S. and Mexico
11-25-2024 06:21 PM
sorry @mesopotamian , PM only has roaming in US and Mexico and not other countries
so zyou won't get sms there
11-25-2024 06:20 PM
I'm currently in the middle east!
11-25-2024 06:19 PM
@mesopotamian You are in the U.S. right now ? Do you have US roaming add on or CAN/US plan ? You need one or the other to use your public mobile service in the U.S.
11-25-2024 06:18 PM
hi @mesopotamian are you in US or Mexico?
data works?
if you are in US, try connect to T-Mobile AT&T and Verizon. Try all three
if you are in Mex, try AT&T
