No call service
Susannalamy
I have been unable to make or receive calls for the past week. I live in Thornbury On. I opened a claim and was told that the problem was external. Is anyone else experiencing this? I don’t know who to contact to get an update.
17 REPLIES 17
dmrocque
Service should be back to normal.  I understand there was an issue with the service off a new tower Bell activated across from Lora Bay a few weeks ago.  Telus/Public Mobile must purchase service from other tower owners sometimes, or mostly, I don't know, but something was interfering with reliable service, especially the 3G network.  Anyhow, all seems to be working properly again in Thornbury.  Wonder if we can expect an account credit for the 3 weeks of interupted service?
Hi @NCousin the 5 bars you see is for LTE network but PM uses 3G network for voice.
I believe PM is aware of the local issue there, but still open a ticket with them, more people open more tickets, hopefully will push them for quicker fix
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
NCousin
Yes same problem since Wednesday last week and today Sunday 26 Feb no service anywhere in Thornbury ON, and yet iPhone shows 5 bars.  However go 4 or 5 km out of town any direction (east, west & south) service is great. It must be a tower signal issue and not your phone. I hope they fix it soon I live near Thornbury as well and if I can’t get a signal it will be a problem and maybe a different service.
@Susannalamy wrote:
I tried your suggestion and switched to 3G but there was no difference.
When you switched your phone to 3G service, did you still have a connection for data and texting? If not, the reason behind this test is to see if there is a 3G outage in your area. With Public Mobile, LTE supports texting and data, and 3G mode support texting, data, and voice calls. With no 3G coverage, you would lose the ability to make or receive calls, even if you have good LTE service.
@dmrocque then it is an issue with the network towers around you.   Oepn a ticket with 9M support and make sure they are aware of the issue, and hopefully they cam provide you an ETA
No worry, this thing happens to any carrier, Rigers will have its turn and yiu can laugh louder 🙂
dmrocque
I have tried all of the resets, restarts, sim card and setting changes suggested and nothing has worked.  It is actually the 4 public mobile users of my household that are having the same issue and my wife is laughing at us as she's with Rogers still.
@Susannalamy  it is good they confirm there is issue.  Don't hesitate, message them for update.  But it is true that it could take long for some site to coms back 😞
Susannalamy
@HALIMACS
Thank you for replying.  I have tried all of your suggestions but there is no change.
My Status is active and Public Mobile says that the site serving the area has issues but that was a week ago and I've had no update since, despite reaching out.
Texting and data work.
Susannalamy
No, unfortunately not!  If I hear anything else, I will let you know.
Susannalamy
I can call and receive calls as soon as I leave Thornbury.  Other Public Mobile users are experiencing the same problem here.
Susanna
I have tried to reconnect with the ticket that was opened last week but there's been no response.  I opened a second ticket today regarding the issue but haven't had a response yet.
@dmrocque
Please try to change your Preferred network or network type to 3G Only (or WCDMA).  Check if the phone connects at to the network at all under the settings
dmrocque
Hi Susannalamy, I'm in Thornbury as well and lost voice call service about a week ago too.  Texts incoming and outgoing still good and data service still good.  Just looking into the issue now.  Have you resolved yours?
@Susannalamy  can you try your sim in another phone and a different sim in your phone.  That might help isolate an issue. Hardware vs network etc
@Susannalamy   Try change your Preferred network or network type to 3G Only (or WCDMA).  Check if the phone connects at to the network at all under the settings.  If it does not connect after changing to 3G, then yes, there is a problem with 3G network where you are.
And can you make and receive calls if you use the phone in another area?
You said you open a ticket and was told the problem was external, did they tell you it will be fixed soon? any ETA?
@Susannalamy - Can you elaborate:
  1. by 'claim' do you mean ticket?
  2. and by 'external' do you mean network?
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
HALIMACS
@Susannalamy
Does your texting and data work?
When you log into self-serve what does the status say? You can also check this by dialing 611 which will give you an audio messaging about status.
Try resetting Network connections, rebooting your device, toggling Airplane Mode on and off, and removing your SIM card and trying it in a different device to see if calling works.
@Susannalamy
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
