New activation not working
DDeeg
I purchased a plan, activated my SIM, but nothing works.
I put my wife's Public SIM in my phone and it's fine.
I used the chatbot to get support, but no one has got back.
Any tips?
RavingRaven
@DDeeg
Customer support will reply back in the morning. Keep an eye on your private message box by clicking on your avatar at the top right corner of your screen to see if there is a message.
DDeeg
Thanks.
Yes, SIM activated successfully.
Yes, tried SIM in wife's phone and another. Same problem.
I created another ticket, hopefully someone gets back and it's an easy one.
@DDeeg
did you activate physical sim? did you test your sim on your wife's phone?
if it does not work too, it is likely an sim provisioning issue.  Easy fix for PM agent, but you just need to engage them by submitting a ticket:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
