Not able to activate SIM
RiteshG
Just received new SIM card . Phone number is registered but not able to activate SIM. Getting SIM error and no text is being sent to activate SIM
7 REPLIES 7
hi @RiteshG
the sim was not properly setup on the system.  you need support to help.
you can submit  ticket by direct message:
RiteshG
Restarted multiple times. After restart phone tries to search network . . After few seconds message appear ' SIM Failure ' with no signal bars. Instead of signal bars it says SOS . I have tried both Apple and Android phones
@RiteshG   Have you restarted the phone since inserting the PM sim?  What is the exact wording for the sim error?
RiteshG
I entered SIM card number in my account . Was able to select the available phone number.
Next step is to enter the OTP code send to new phone number to activate SIM. I am not getting that text as phone is not recognising SIM . It is giving SIM error . Nutshell I got the new number but SIM is not working
@RiteshG   In your account, have you entered the sim card number?
RiteshG
This is the new phone number /SIM CARD PURCHASED FROM PUBLIC MOBILE . Phone number is assigned but SIM is not activated
@RiteshG
Is the current number registered with PM or another carrier?
Other carrier - You can only activate the PM SIM on the PM app on phone then follow all 6 steps to port your number over.
PM account - go to Account tab>Change Your SIM Card and enter the new SIM card number.
