2 hours ago
Almost every time I try to make an outgoing call, the network drops to no service and the call doesn't complete.
SMS and mobile data work normally.
My partner attempted with my SIM in his phone and he got much the same results.
All the calls were attempted in our home, which for as long as remember never had this problem until the last few months.
Any idea what the issue could be?
an hour ago
HI @Ren97
i think you need support agent to refresh your account and check
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
an hour ago
Tried 3g only as preferred network. Showing "H" most of the time. However, it is showing full signal strength when I go elsewhere. However, I'm still unable to make calls most of the time.
I have a moto g fast, and my plan Is just unlimited talk and text with 2g of data.
2 hours ago
I would say try a new sim card , especially if the problem is following to another device .
2 hours ago
HI @Ren97
so, calls were when you are away from home?
what phone do you have? brand and model?
and what plan do you have ?
did you try changing your network mode to 3G or WCDMA only?
2 hours ago
No. I've been on public for several years. Nothing has changed except my ability to have a phone call.
2 hours ago
Did you just recently switch from another provider?
2 hours ago
@Ren97 Lots of folks complain of dropped calls around here myself included . Public mobile acknowledged the issue awhile back and said it had since been resolved . Never went away for me best thing I. An suggest is try phone set to 3G for a little bit see if that helps then switch back to 4G/LTE or 5G and cross your fingers
2 hours ago
Yes, I can confirm that WiFi is turned off during these attempts.
2 hours ago
Hello,
Can you confirm that your wifi is disabled when you do the test?
2 hours ago
I forgot to mention, sometimes the call does actually go through, it lasts for about 30s-60s before dropping the call.
